Diode - Marking code . Need help.
Hi all,
I am looking for to identify a through-hole diode with marking code 2 18 (printed in two rows: frist row 2, second row 18). It is a glass case diode. Can anyone help to find its datasheet and its specification?
I appreciate your help.
Thanks.
RE: Diode - Marking code . Need help.
Many times it is impossible to find the exact replacement. If you don't get the help you need, then consider using a standard diode.
You may have an idea about the specs for this diode. Is it a switching diode, a zener, a shottky, germanium, perhaps? or just a plain rectifying device? Voltages? Currents? Most standard diodes do the job today.
I once had a problem finding an old (German "hand-made") diode replacement and finally got one from an antique piece of equipment. Out of pure curiosity, I cheched data like forward drop, leakage current, capacitance and such things. Found that good old 1N4148 did the job a lot better. Should have tried that firsthand.
Gunnar Englund
www.gke.org
skogsgurra,
Thanks for your input. I also think about using any compatible diode, but I have no specificaton about it (diode with marking code 2 18). I am not sure it is whether zener or regular diode. However, it was used in a switching mode circuit and was connected across a MOSFET, and it was a part of pwr supply for lightsource equipment.
Can you provide a sketch of that part of the circuit?  We could probably tell what diode we would design-in for it.
Keith Cress
Based on what we know up to now, there is a fair chance that it is a fast or ultrafast diode, and probably fairly high voltage. Can you identify the package style? These usually denoted DO-** where the ** is a couple of numbers. This will give some indication of the current rating.
  I don't suffer from insanity. I enjoy it...
Keith,
The unit is at my work, and I have neither a schematic nor a drawing for that part of circuit. I can trace the circuit and make up a partial schematic, but it will take me some time.
ScottyUK,
I found it defective becasue the forward diode direction was opened, and I am looking for its replacement, but have no idea what kind of diode it is.
It is an axial package type, but not sure what type of DO** is it (DO-41, or DO-35, not sure)? It is very small in diameter and a glass case type with orange color. It was marking with two lines: 2 and 18. I also saw some diodes marking like that but different numbers such as 2 and 14, 2 and 16, and 2 and 24. Just want to know who made it and what these numbers stand for.
Thank y'all.
Directly across a FET.... On a lighting power supply...
What kind of lighting supply?
Keith Cress
itsmoked,
It is a lightsource eqipment, which provides light though an optical cable to a microscope or to a camera in surgical equpipment.
Sorry I wasn't clear in my question..  The "type" of light source was what I was after because it might give a hint to what-all the diode is doing.
Your application smacks of incandescent if 8 years or older.  Halogen if 8 to 1 years old and possibly LED if 1 or less years.
If it is either incandescent or halogen then it probably isn't a zener.  Just a regular or fast diode for handling the tungsten inductance.
At this point I concur with skogsgurra.  Put in a 1N4148.
Keith Cress
