Section volume cut in assembly
How do you create a section volume cut of an assembly at a specific location such as a plane or surface?
Thank you,
ryengnut
Thank you,
ryengnut
RE: Section volume cut in assembly
Well, that depends...
What do you want to do with it? Simple analysis, or parametric geometry linking?
CAD design engineering services - Catia V4, Catia V5, and CAD Translation. Catia V5 resources - CATBlog.
I just need to do a mass measure between two sections of the assembly.
ryengnut
Insert a new part in your assembly, and follow the instructions here:
http://www
Make sure to use the Part Bodies, and not individual surfaces when selecting your intersection data. (if that's what you really want)
The method that you suggested is similar to just creating a CATPart from a product but allows you to choose what parts you would like to bring over to the new part, which is really handy.
I continued looking in the help files for some idea on how to create a section cut a specific location and found it!
When being in the sectioning definition dialogue box, select the position tab and click on the "geometrical target" icon, then select a plane or face that you want the section cut to be located.
ryengnut
I don't currently have any DMU functionality, and I remember (at my former employer) always having this issue with not being able to place the planes. I don't know how far it goes back, but it would have been nice to know. :)
Now that you have that, you can export the sections, (under the 'result' tab) and you should be good to go. It should be much more efficient than my previously mentioned method.
Good luck!
