Roark's Formulas for Stress and Strain
I need help interpreting a formula in Roark's book. On page 472, Table 26, case 11d, the formula for the maximum stress contains a variable "q".
My question is: For the triangular loading shown in the diagram, what is "q"? The total load on the plate? The maximum load at the base of the plate? Obviously, for a uniformly distributed load, "q" is simple. However, I can't seem to find any description in the book for what "q" is when the load is triangular, so I thought that someone out there with more experience might be able to help.
Thanks in advance.
Thanks in advance.
RE: Roark's Formulas for Stress and Strain
I'm assuming your book has same table numbering and all as my Fifth Edition.
Table 24 defines it as the load per unit area.
The problem I always had with Roark's book was that in most cases where I used one of the formulas I did not have a method to verify the answer. So if I used an incorrect value for one of the coefficients I would not know it.
Look also in the site below, under Plates -> Simple bending -> Rectangular -> 2 adj.clamped,2 free -> Hydro load for the case that interests you.
prex
http://www.xcalcs.com
Online tools for structural design
