Bonnet Flange Thickness
Can anyone help me how to determine the valve body/bonnet flange thickness? The flange is square with circular gasket. I was following the formulas in BPVC VIII, but I am not sure how to determine the flange outside diameter. Should it be the largest circle inside the square flange or outside the square? The results are quite different. Appreciate if someone can help!!!
RE: Bonnet Flange Thickness
I am not an authority on this subject but, I would take the conservative approach and use the largest circle inside the square. If you use the circle outside the square you are taking credit for metal that does not exist and this could cause gasket leakage problems.
More metal, but less risk.
ABScott
For economical reasons, I would like to see if I can eliminate some extra weights by modifying the equations, or if there is some formula to use for a square flange which doesn't state in BPVC.
Valve components.
http://ww
