pipe weld question
pipe weld question
A large machine we build and sell has an air compressor that feeds an air holding tank. The compressor is either diesel or electric motor driven. The air holding tank is an ASME "U" stamped pressure vessel, MAWP is 250 psi.
There is a short pipe piece that connects the air compressor to the ASME air tank. The pipe is basically a 90 deg. elbow with a butt welded flange on each end. (8" nom. dia.) This pipe spool piece connects the compressor and the ASME pressure vessel. (there is a vibration coupling in the line also.) This pipe piece is a subcontracted purchased item, and I recently noticed visually some weld quality issues on the flange welds.
My question is: Is the manufacturer (vendor) of this welded pipe piece required to have some code qualification, welder certification, or certificate of authorization, ...like a "PP" stamp?
Thx!
Thx!
RE: pipe weld question
