Rebar Corrosion in Elevated Slab
What would be the best testing plan to determine the extent and severity of corrosion of a reinforced elevated slab exposed to salt water byproduct of a manufacturing process?
Are there any remediation procedures for steel only slightly damaged?
Also, would the concrete itself be affected?
