Wiring Assemblies
Wiring Assemblies
Do any of you use Solidworks for wiring assemblies?
We cuurently use solidworks for all our drafting needs, except for wiring diagrams. I would imagine it is possible, but is it really time effective creating BOM, multi wire assemblies and connectors all for 2D?
RE: Wiring Assemblies
If you will do a lot of wiring assy's, I suggest looking into Router from SW.
Chris
Systems Analyst, I.S.
SolidWorks/PDMWorks 05
AutoCAD 06
ctopher's home site (updated 06-21-05)
FAQ559-1100
FAQ559-716
I have played with Routing a bit, but not enough to get a good handle on it. It seems better suited for hard piping, rather than loose wiring harnesses.
Chris
AutoCAD 06
FAQ559-1100
FAQ559-716
Although the router is new and may not have every feature I would want, it can automatically attach point A to B with 3D "solid" wire and you can specify connectors at each end, like a multi-terminal Molex. Then it will create a 2D nail board in the flat with the proper lengths of wires.
