Heater Bands
Heater Bands
I am trying to find a Heater Band for a pressure vessel that can go up to >700F. I wanted to know if there is any kind of a band that is temperature controllable. Can I maintain 700F for a few hrs?
Thanks!
Thanks!
RE: Heater Bands
Griffy
RE: Heater Bands
CODE
They have some for barrels to go up to 900 deg F.
_______________________________________
Feeling frisky.........
www.tailofthedragon.com
RE: Heater Bands
http://www.watlow.com/products/heaters/ht_band.cfm
http://www
ko (www.ecooling.biz)
RE: Heater Bands
RE: Heater Bands
I use inductive heat band types around drums: one thing to consider is the uniformity of heat transfer in your vessel.
If the liquid to be heated is impressively dense and static inside the vessel, then you might have to contend with "Heat Affected Zones" where the material is over heated in certain spots. I'd recommend that you find a way to slowly circulate the liquid inside the vessel during heat application, if not already.
