Impact Tests For Section IX PQR
Can you take a PQR that satisifes your other mechanical tests and combine it with another PQR that was only impact tested to create a WPS or does it have to be done all at once? The issue is the impact testing requirement was simply overlooked on the first round.
RE: Impact Tests For Section IX PQR
thank you for the quick reply.
