Corrupted file maybe?????
When I load a product in V5 it gets half way through the loading visualization then I get a error message saying " Command Interrupted" then the PC locks up and Catia shuts down.
Im thinking it might be a bad file.. Or maybe not enough memory. Any suggestions?
RE: Corrupted file maybe?????
How much ram do you have. Watch the ram consumption in the task manager, this will tell you if you run out. It could be crashing due to visualization. Down tune your parameters in the performance section.
We can try some additional stuff, try this first and see what happens. All else fails, a good old reboot is in order.
Derek
Don't be so sure! It's most likely memory related, but not necessarily deficient system memory. It could be your video card, or it could be a memory leak in your current Catia version. (which is what, by the way?)
Memory spikes are never a diagnosis, in and of themselves...
CAD design engineering services - Catia V4, Catia V5, and CAD Translation. Catia V5 resources - CATBlog.
Increase the virtual memory (swap file) on your hard disk thru WINDOWS Configuration Panel->System->Advanced->Performance
-Hora
