Heater Bands
Heater Bands
I am trying to find a Heater Band for a pressure vessel that can go up to >700F. I wanted to know if there is any kind of a band that is temperature controllable. Can I maintain 700F for a few hrs?
Thanks!
Thanks!
RE: Heater Bands
http://www.watlow.com/products/heaters/ht_band.cfm
http:/
ko (www.ecooling.biz)
RE: Heater Bands
batthina
You do not address what it is you trying to achieve. Be very careful heating a vessel shell as it will affect (reduce) the vessels ultimate pressure limit. If you exceed the design criteria you can have a catistrofic failure of the shell and injuries can be sigificant.
Good Luck
Best regards
pennpoint
