Allowable Stress of 316SS
What allowable Stress can I use for 316 SS plate? The plate will be in a cool atmosphere, about 40 degrees in the winter. Thanks.
RE: Allowable Stress of 316SS
Often items like these are not covered by specific codes or standards. You must have reasonable and prudent engineering justification for the values that you use.
The amount of detail concerning loads and the risks to persons and property often direct selection of safety factors.
If you know the loads with certianty and there is little risk then a 2 or 2.5 factor (based on minimum specified strengths) may be fine.
Less certianty and greater risk, values of at least 4x become more realistic.
History and past practice are often your best guides.
Rust never sleeps
Neither should your protection
http://www.trent-tube.com/contact/Tech_Assist.cfm
corus
