"Content loss" when importing a .txt-file into Matlab (sums differ)
when I am importing a .txt-file with one column and about 1 Mio. rows, I am always "losing" some content.
To be a bit more precise: each row contains a figure equal or higher to 0. The sum of the rows' content in my txt-file is 3.598.591 (= total number of trips; I know this figure from my simulation program), while the sum of the rows' content in Matlab, using sum(vector), is only 3.564.907.
Has anyone an idea why I am losing 33.684 trips when I am importing the txt-file into Matlab?
Thanks for your help!
Kerstin
RE: "Content loss" when importing a .txt-file into Matlab (sums differ)
Have you demonstrated the problem with a shorter version of your text file?
Have you re-exported the results you read in, and then compared the two text files with something like winmerge?
Cheers
Greg Locock
