What's inspection code
Hi.
I want to know if somebody knows about inspection code of weldment of threaded-and-seal-welded bonnet valve.
thanks
RE: What's inspection code
You need to provide more information. Is this a weld repair to an existing valve,  a new valve that has been modified for this seal welding or what?
a new valve.
thanks
As a minimum, for the seal weld and surrounding base metal use ASME Section VIII, Div 1 acceptance criteria for wet fluorescent MT or Liquid penetrant testing (PT).
