Body to bonnet weldment
Hi.
I want to know if somebody knows about inspection code of weldment of body to bonnet welded after body to bonnet is threaded by threads
thanks
thanks
RE: Body to bonnet weldment
It seems this is a duplicate of your other post on
QC, Inspection & Testing engineering Forum
(3480 members)
forum286
If yes, you should direct people to the other post for their replies (it is better to keep replies to a single location rather than split), especially since someone has already replied to the other post.
"Do not worry about your problems with mathematics, I assure you mine are far greater."
Albert Einstein
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
