Which Service Pack to install with 2006?
We are about to upgrade from 2004 to 2006. Due to our installation process we would like to install a service pack at the same time. Which SP has been the least problematic for 2006? Since installing SP's after the fact is not viable we would need to be set on one that will not cause problems.
SW2004 SP0
SW2004 SP0
RE: Which Service Pack to install with 2006?
I think SP3.4 was pretty good...SP4 just came out so I have idea how good or bad it is... but so far it's working very well for me.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
Jeff Mowry
www.industrialdesignhaus.com
Reason trumps all. And awe trumps reason.
I will make note that a clean install and registry clean up should be done.
