Rowe's Moment Reduction Info
I'm working on a sheet pile retaining wall project. I would like to build a spreadsheet application containing moment reduction curves. At present, what I've done is eye-balled existing curves in Pile-Buck's and Das' books and put those numbers into a spreadsheet. The plots look nice and everything, but is there a better source of the data? Is it copyrighted/protected some other way? Any information is appreciated.
RE: Rowe's Moment Reduction Info
I posted some months ago the Mathcad sheet TESTACA.mcd that solves sheet pile walls with a single tie-aback level. You can download it from the Collaboratory site. Also there is another sheet dealing with the anchor wall.
