Fonts in I-deas 11NX
I saw in help file that in I-deas 11NX true type font can be used.
How to set param file like it is described in text?
RE: Fonts in I-deas 11NX
This is straight from UGS' website:
PRODUCT:      IDEAS
SUBJECT: I-deas9m2: Adding additional font in wireframe font command.
SUBMITTED BY: XXXXXXXXXX           SUBMITTED DATE:   01/17/2003
IR #:                XXXXXXX                 DOCUMENT ID:      001-4696421
PLATFORM:      INTEL                       OPERATING SYSTEM: WINDOW
OS VERSION:    2000_SP2                 PRODUCT VERSION:  V9M2
HARDWARE/SOFTWARE CONFIGURATION
Family        : I-DEAS
Application : DESIGN
Function    : MASTER_MODELER
Subfunction : ALL
Release     : V9M2
Platform    : INTEL
OS        : WINDOW
OS Version  : 2000_SP2
SYMPTOM/PROBLEM
How to add more font style to Wireframe Font command.
SOLUTION/WORKAROUND
Turn on the param_file setting: usenttruetypefonts: 1, this shows up all of
the true type fonts that Windows has.  There may be some fonts that I-deas
won't like.  That is mentioned in the on-line help.
If you would like to add more fonts, add them to the WINDOWS\FONTS directory.
If Windows accepts that it is a font, I-deas should then accept it. If like to
create own font, need to get a font creation program, a third party product
that should be able to find in the market.  There has been shareware versions
of these offered as well.
You cannot add any additional fonts to the forms (outside of the true type for
Windows).  So if you have one on Unix, it cannot be added.
REFERENCES/NOTES
Note: param_file= ideas_param9 found under /team/mstr/config directory.
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
