Inserting custom properties into dimension text?
I want to be able to insert a custom property into my dimensions. Not necessarily into a note. For example i want my dimension to read MH-(custom property). So that it updates automatically when the property changes due to a change in my design table. It would be even better if we could directly link to the design table. However any help is appreciated. Thanks.
afro2
RE: Inserting custom properties into dimension text?
Hi solidben,
I've already sent in an enhancement request to SolidWorks for this. For example, we regularly have notes where we would stated:
INSERT BOLT (ITEM 5) INTO MOUNTING PLATE (ITEM 10) etc.
Would be very useful to link the item numbers. Perhaps you could put in an enhancment request.
You cannot add it to a Driving dimension of a model, but you can (in a drawing) add it to a driven dimension which has had the <DIM> replaced with a linked note. The note can reference the custom property.
A table in the drawing (showing the actual values of MH) might be a better way though.
cheers
Helpful SW websites  FAQ559-520
How to get answers to your SW questions  FAQ559-1091
