Application to report RAM Usage?
We are thinking of having an application run in the background to prompt User once their RAM has max'ed out and their computer is paging to the hard drive. Or maybe prompt them once 80% of the RAM is being used so they are aware and can start thinking about a good time to shut down SolidWorks and restart.
I saw a post one time that someone had written an application that would pop up a dialog box once a certain amout of RAM useage was reached, but I have been unable to find that post again? Does anyone remember what thread that was in?
Ken
RE: Application to report RAM Usage?
I don't remember that program.  However, several pieces of freeware can do the trick (if they still exist).  You may want to check the utilities section under freeware at:
www.snapfiles.com
It's a great place to get reviews on freeware, as well as "clean" applications.
Also, built into TuneUp Utilities 2006 is something that works like that.  You can download that free and try it for a while to see if it has what you need:
http://www.tune-up.com/
Jeff Mowry
www.industrialdesignhaus.com
Reason trumps all.  And awe trumps reason.
