Fluid at 5000psi and 700 F
I am trying to find a liquid that can be pressurized to 5000psi and heated up to 700 degF.
I will be using this fluid in a pressure vessel with heater bands around it. What I am trying to do here is very similar to HIPing, where I want to substitute gas with a liquid. I will be HIPing Polymers/plastics. I am not sure how water behaves at these conditions. Also, I was looking into some polymer quenchants that I thought I could use. But, could not get much info.
Looking forward to hear your suggestions.
Thank you.
Thank you.
RE: Fluid at 5000psi and 700 F
Syltherm 800 (Dow) or
Therminol 75 (Solutia formerly Monsanto)
both are good up to and above 700F.
best wishes,
sshep
p.s. what is HIPing?
Mike Halloran
Pembroke Pines, FL, USA
Mike - The normal sintering tremperature for PTFE is around 700F.
I am trying to apply pressure isostatically on the polymer sample. It could be a 2" OD, 7" long solid billet inside the pressure vessel. I am not sure if we can achieve equal pressures in all directions using silicones. Please advice.
http://www.freepatentsonline.com/4889668.pdf
Won't conventional HIP equipment work for you?
when operting at high pressure , be sure that there is positive relief of overpressure. Sometimes, if there is a temp excursion , there may be new chem species formed that may lead to rapid overpressure unless such relief is provided.
Mike Halloran
