I'm back to discuss the design of a chime, a circular tube to make a sort of bell like sound during a church service. For you old timers, we talked about this about four years ago. Back then, my time ran out and I decided to order a single chime tube from an orchestral chime producer. Makes me feel like an engineering wimp that I couldn't do the calculations, but a wise man once said (e.g. Clint Eastwood) "A man's got to know his limitations." But seriously folks ...
It is my belief that to make a proper chime, you cut a tube to the length corresponding to the acoustic resonance length for an open-open tube resonating at the requisite frequency. For a concert A of 220 Hz for example,
344 m/s / (2 x 220 Hz) = 0.782 m -or- 30.78 inches
The exact frequency is not important, but let us assume we will be shooting for the concert "A" for the purpose of this discussion. (220 Hz = 1382.3 rad / s)
So the tube will be 30.78 inches long. However, my experiments led me to conclude that the mode of vibration I am seeking in the design is not the vibration of a free-free rod in its second mode, which I originally believed, but rather a "bell" mode as suggested in this forum years ago. I interpret that to mean a shell mode of vibration of the tube wall through the thickness.
If this is the case, then I guess that if the tube were considered narrow relative to its length, the only variables we are working with are the material properties of the tube (the mass density and Young’s modulus) as well as the diameter and the wall thickness.
I still have some aluminum tube from the original experiment so I would like to stick with the aluminum for now. (E=10,000,000 psi & p=165 pcf) The diameter of the tube is around one inch. Using these values, what would the wall thickness have to be to get a good "Bell" mode? Is it possible to describe the arithmetic in a post? Thanks for everyone's help. - Dinosaur
Den Hartog's "Mechanical Vibrations" has a formula for frequenies of vibration a cylinder which is sometimes applied to motor cores. I'll post that formula tonight.
===================================== Eng-tips forums: The best place on the web for engineering discussions.
Also Tom Irvine (Vibrationdata.com) is a frequent contributor at this site and has some great material available for a small fee. His file on ring vibration modes shows:
Ring frequency = sqrt(E * mu) / (Pi * d) Where mu is mass density This is the speed where wavelenght = circumference. For aluminum this frequency in hertz is 63,790 / d when d is in units of inches.
He also details in-plane bending modes and out-of-plane bending modes. I think out-of-plane bending modes are not relevant unless the cylinder length is much less than it’s diameter.
On a similar subject, I have a question for folks here:
For the mode described by Ring frequency = sqrt(E / mu) / (Pi * d)
What is the mode shape? I picture this as a traveling wave rotating around the ring. From my perspective we could add a mode number n and say Ring frequency Fn = n* sqrt(E / mu) / (Pi * d) This corresponds to any integral number n of wavelengths in one circumference.
Then the deformation would be given by y(theta,t) = cos ( w*pi*Fn * t – theta / n) For example n = 2 would be an oval deformation rotating at twice the fundamental ring frequency.
Does this sound right to you guys? The rotating mode shape may or may not be interesting for chimes (what do you guys think?) but is very interesting for motors.
Last correction (hopefully): "Then the deformation would be given by y(theta,t) = cos ( w*pi*Fn * t – theta / n)" should have been "Then the deformation would be given by y(theta,t) = cos ( w*pi*Fn * t – theta * n)"
I am confused (but, of course not for the first time). Your formula does not have the wall thickness, t, as a variable. This is counterintuitive. Am I missing anything?
Just to clear up the clutter of my previous comments, let me start again:
Tom Irvine's paper mentions 3 types: 1 - ring frequency 2 - in-plane bending modes (take a circle and squash it into an oval or a clover). 3 - out-of-plane bending modes (take a circle and bend it like a saddle).
#3 I rejected for this scenario on the basis that a long tube does not seem likely to undergo this deformation.
#1 - (ring frequency) - he gives frequency as f = sqrt(E / mu) / (Pi * d) where mu is mass density in his terms. His derivation is that this is based on the time it takes to travel one circumference at the speed of sound in the material sqrt(E/mu). He also seems to describes this as a compression/expansion mode. I added the stuff about higher order modes on the basis that it sounded more like a traveling wave to me...let's forget that for now.
I don't see this equation in any other references. You guys object on the basis of no dependence on thickness? Could be... I don't know.
When I look at the derivation I see there are two errors: I = (1/12) * h*t^3 and mu = mu * h *t
Now one more to consider: Den Hartog gives the following for in-plane bending mode: f = (1/[2Pi])*i*(i^2-1)*sqrt(E*I1/(mu*R^4)) / (sqrt(i^2+1))
If I compare with Greg I see two discrepancies: mu=m/L in Den Hartog's formula takes the place of m in Greg's formula. That seems ok as long as Greg's m is intended to mean mass per length.
The other discrepancy is that Greg's denominator has (i^2+1) whereas Den Hartog's denominator has sqrt(i^2+1).
I have two other sources which show the sqrt(i^2+1) in the denominator: one is Tom Irvine's paper (before the rectangular substitutions). The other is an article by Alger. Based on the above I am inclined to believe Den Hartog's formula is correct for #2 (in-plane bending). Greg can you check whether perhaps you have omitted a square root from around i^2+1 in your denominator?
I have one more question (if Dinosaur doesn't object to me messing up his thread). Is this in-plane bending mode associated with the above frequency equations restricted to a standing wave where the nodes never change? Or can it be a traveling wave where the modes rotate around the circumference?
Ok, I wouldn't have called (1) a ring frequency (but there's nothing wrong with it as a name, and it can be a very important mode), but that is essentially a one dimensional plane wave, hence the absence of t.
for (2) yes I forgot the square root.
In my experience out of plane bending modes (type 3) in brake rotors sometimes rotate with the structure, and sometimes lock to the brake pads, and let the structure pass underneath them. I suspect type 2s would be just as annoying.
For this tubular bell I strongly suspect that the beam flexural modes are far more important than the in plane bending modes (type 2), and I also doubt that a conventionally proportioned tubular bell would exhibit pure type (2) modes. A quick FEA would confirm that the high order modes are dispersed in length and theta, forming a patchwork, typical of high frequency modes in thin walled structures. These are relatively inefficient radiators as adjacent patches are in antiphase and so cancel each others contributions.
Cheers
Greg Locock
No problem with the discussion going where it wants to go. We had a lot of fun with this thread the first time around including discussions of boundary conditions, location of nodes, etc. It is a fun theoretical discussion with a real world problem most of us can relate to. If we get too far off track, I'll just restate the question.
Regarding the ring mode ...
It sounds to me like a compression wave in-plane traveling around the circumference. That certainly is a mode, but I doubt it would have enough energy to excite the air within the tube to create much sound.
As I said earlier, the original thread from four or more years back included much speculation that the important modes would be "Bell Modes" while I was attempting to compute beam modes. I am not sure what a bell mode is but I have an idea. I assume it is a shell mode of the tube vibrating thru the thickness, but the pattern of crests and troughs forms a kind of checkerboard over the surface if you were to unroll it. Since the length of the tube is so much greater than the diameter, it seems to me that it would approach an infinitely long medium.
I could be all wet on this. Heck, it might not even be a bell mode. All I know how to do is calculate beam modes, and I don't think that is the answer.
Anything you have to offer in the discussion of vibration of a long circular tube is relevant and welcome. Thanks again. - Dinosaur
Greg-L
It will take me a moment to digest what you are saying. You just posted while I was in the middle of this.
A lot to read. I wanted to make one quick clarification. I may have jumped to conclusions when I said Tom Irvine's formula was in error. Those substitutions of "I" and mu I recognize as rectangular. I initially thought they were wrong because we are dealing with a tubular geomtery. But thinking again for in-plane bending maybe it is correct?? After all side-view of a tube looks like a rectangle.
To add to previous comment, the derivation uses I (called Iy) as Iy = (1/12)*h*t^3 with comment that this applies to a thin ring. Then later m = mu*h*t with no comment.
I guess if you slit the tube axially, unroll it (sincd it's thin and therefore radius of curvature large)and look into the cross section of the slit, then it looks like you're looking into the end of a rectangular beam.
Dinosaur - it might be cheating, but how about working the problem backwards? If look at the pitch of two different chimes then we can calculate the frequency ratio (octave = 2:1, fifth = 3:2, fourth = 4/3, major third = 5/4, other intervals can be determined as well). If you look at the the dimensions then we can predict what the frequency ratio of those two sets of dimensions would be under various types of vibration: #1, #2, #3, or the open/closed air column vibration modes (perhaps there is combination of metal vibratio mode and air column mode at approx the same frequency?). Anyway, that might give a clue which type of mode is responsible for the sound.
Your website resource is exactly what I needed. I had tried to compute the beam modes before, and I guess I had messed up the conversion of the mass from pcf to slugs/cu. ft. or something because the answers I had then did not correlate with my test results. Back then I thought the beam modes were the important sturctural modes and the challenge was to match a beam mode with an acoustic mode for the tube length.
I have a piece of one in dia. galvanized steel conduit 63" long. I have computed several modes for various lengths shorter than the 63". Now I am going to locate a hang point at 22% L from one end and cut the tube to length to match a mode. If it resonates, then I will cut it down to the next length, and see if it resonates again. If I am successful, it will prove the math you provided me is correct. Thankfully, I have Mathcad and can use this to "design" other chimes.
The next step will be to experiment with the materials available in my area to find a material that gives good tone. After that I will make a chime (one note) for my church. When I get to that point, that I have verified your math and can "handle it", I will become a supporter of your work at your website. You've earned it. Thanks - Dinosaur
Perhaps the most interesting point from Tom's analysis is that there appears to be no equality between the "beam" longitudinal and bending modes and the acoustical modes inside. (Although, you could argue that the 2nd bending modes are possibly exciting the 4th acoustic modes)
It also suggests that ring frequency and cylinder modes (c.f. beam modes) will be too high frequency to be of any significance.
A very interesting experiment would be to find out what happens when the 2nd beam mode does match the fundamental acoustic mode. Perhaps, Dinosaur, you could make one that matches and one that doesn't and let us know the difference between the sounds.
Tom, does the longest chime sound different to the others because the initial response is dominated by the "untuned" 3rd beam mode instead of the "tuned" 2nd beam mode? It could just be that the position of the striker is such that it is closer to a 3rd bending antinode than a 2nd bending antinode.
It is interesting to see that the (mostly) dominant 2nd beam mode has a much shorter RT than the 1st beam mode. Is this because it is a better radiator and has higher radiation damping? That seems like a big difference in damping to be explained by radiation alone. Perhaps the suspension has more damping imfluence than one might initially think.
The good news for you, Dinosaur, is that a simple Euler-Bernoulli beam model will be plenty accurate enough for your design and will save an awful lot of mucking about with tedious elasic cylinder theories and FE models!
In an attempt to clear up your confusion about the ring frequency (although I fear it may have the opposite effect), I offer the following.
The "ring frequency" (yes it is the correct term) is the frequency where one longitudinal wavelengh fits exactly around the circumference of the ring or cylinder. It is easier though to think of just the ring for now.
The ring frequency is often called the "breathing mode" becuse the ring simply expands and contracts whilst retaining its circular shape. Imagine a thin ring divided into equal sized elements about the circumference. Now stretch each element slightly along its length. The ring remains a circle but it now has a larger radius. Now shorten each element and the reverse happens. It is still a circle but the radius is smaller than when we started.
For a ring, this is indeed a mode of vibration but a rather peculiar one (for a start it either has no nodal points or every point is a nodal point, depending on how you look at it!). The strain on each element is entirely in the plane of the element (you are just making it longer or shorter). It is a longitudinal motion. However the effect on the displacement of ring as a whole is ENTIRELY OUT-OF-PLANE (i.e. the ring expands and contracts).
So now you can see why the formula for the ring frequency involves the longitudinal wave speed (sqrt(E/rho)). It is becasue the motion is caused by longitudinal strain in the cylinder material.
This is an extreme example of what cylinder dynamics is all about. Out-of-plane motion of the cylinder surface be caused by in-plane strain of the cylinder material and vice versa. As I said, the ring frequency is an extreme example. Most modes of vibration of a cyliner are a complex mixture of out-of-plane and in-plane behvaiour.
For a cylinder, the ring frequency is just that - A frequency. It is not necessarily a mode of vibration. It serves as a useful marker. Below the ring frequency we have the complex mixture described above. Above the ring frequency this behaviour starts to sort itself out into something we are more familiar with. By the time the frequency reaches about 1.5 times the ring frequency, out-of plane motion is caused purely by bending strain and in-plane motion is caused purely by longitudinal strain. As a result the whole thing starts to behave in the same way as a flat plate making the maths a whole lot easier (thank God).
After getting my piece of 0.94" dia conduit, I set up a spreadsheet to compute the frequency of the first three beam modes along with the first seven acoustic modes. Then I plotted them on a graph with the length of the rod on the horizontal axis and the frequency on the vertical. This provided an interesting result in that the second and third beam modes are very nearly double and can therefore be tuned to two acoustic frequencies at the same time.
At the point where an acoustic frequency intersects a beam frequency, I expect to hear a clear resonant frequency. It is my belief that quality chimes are manufactured so that you obtain a nice blend of notes all resonating at the same length, but at different acoustic resonant frequencies. When I get a little time to cut my conduit, I hope to verify this.
The first step will be to place a hole @ 22% L and hang the tube. Then I will observe the behavior when I strike it. 63 inches is not a resonant length so I should get a short lived "harsh" sound when I strike it.
Then I will trim the tube above and below the hanging point so this point stays 22% L from the top. When I get near L = 45 inches, I should begin to hear the second and third beam modes resonating. For the musically minded, these two notes are an interval of an octave apart in the scale. So if I have everything right I will get a 300 Hz and 590 Hz note when I strike the tube.
After I hear this, I will decide if I am going to proceed to the next note of interest which occurs at a length of 33.25 inches. At this length, my spreadsheet shows the first beam mode intersects the first acoustic mode at around 200 Hz, a little below the concert A = 220 Hz I would like to get. However, in order to get this frequency, I would have to mill off a tiny bit of the wall thickness, which I am not interested in doing right now.
I should be able to play with my tube sometime in the next week. I'll keep you posted.
Dinosaur, this is a quick FEA problem, if you give me the dimensions of your tube (OD ID length) I'll run a model and let's see if we get any correlation.
Cheers
Greg Locock
Off the top of my head, I am working with two steel tubes. One is a galvanized fence post with an O.D. of 1.515 inches and a wall thickness of 0.068 inches. It is currently about five feet nine inches long, but I plan to cut it down to a resonating length where a beam mode matches an acoustic mode.
The other is a galvanized piece of electrical conduit (also steel) with an O.D. of 0.94 inches and a wall thickness of 0.05 inches. It is currently 63 inches long and I will cut it down to a resonating frequency.
I plan to hang each tube at 22% L from one end and hit it with a wooden hammer made from oak just for this purpose.
I gave you the resonant frequencies I think will work so try those lengths and see if you get the same answer.
I couldn't work on it today because I had to take my son to his ballgame. Tomorrow I have choir practice, so maybe I will work on it Thursday and have something to report on Friday. Thx - Dinosaur
I looked at Tom's articles and I see the variation of frequency vs length follows the free free beam very closely. Chime___L____f1___f2 1_____34.7__244__663 2_____32.6__278__753 3_____30.7__312__850
Should follow f~1/L^2 chime three fundemantal should be 244*(34.7/30.7)^2 = 311 pretty darned close.
But the series of tones for a given chime seems to vary somewhat more from the ideal. The ratio I see for the first 4 frequencies from Den Hartog a1=22, a2=61.7, a3=121, a4=200
For chime 1 the measured frequencies were f1=24, f2 = 663, f3 = 1272, f4 = 2050
If the measured frequencies follow Den Hartog's ratios, then fi/ai would be a constant.
Using f1, f2, f3, f4 for the first chime we have: f1/a1 ~ 11 f2/a2 ~ 10.75 f3/a3 ~ 10.5 f4/a4 ~ 10.25 Close enough to fit the pattern but makes me wonder why it varies this way. Any ideas?
A new question - what determines, which bending mode is the one that sustains (and presumably the one that we hear as the amin musical note).
I think you have touched on two hypotheses.
First would be that the bending mode with same frequency as the an air-column frequency might be the one that is amplified or perhaps resonantes. But the direction of vibration is transverse for tube bending and longitudinal for air column vibration, right? Doesn't seem like there should be any coupling. Maybe if the resonant frequencies are very ver close to each other, even very small cross coupling between longitudinal and lateral would become important?
Second you alluded to 22% as the point to suspend the chime. Presumably this arises from the fact that the first nodal point for free free beam is 22% of length from the end. It makes sense to me that the mode that has a node at the point of suspension would last the longest. In Tom's examples, the 2nd mode always lasted the longest. Where were those suspended? Applying the same logic as above it would have to be 13% from the end to correspond to the node of the 2nd mode.
Back to the FEA - by inspection I'd expect the shell modes of those tubes to be in the 2-4 kHz area, that is, everything below 1 kHz will be adequately explained by beam bending. For reasons that I am yet to determine my FEA model isn't solving. Grr.
Electricpete - you've raised a good point, I doubt that there will be any strong coupling between the axial air mode and the radiation from the tube bending modes. The radiation efficiency of each bending mode is strongly affected by the ratio of the bending speed of the tube compared with the speed of sound in air. But, as the nodes and antinodes get closer together (as frequency increases) the radiation efficiency plateaus as the contributions start to cancel.
Possible reasons why the harmonic frequencies don't follow theory - shear stiffness of the tube (small), second order effects from the suspension system (small), fluid loading of the structure (very small). Might be worth asking an instrument maker.
Cheers
Greg Locock
Did you check the mass of your tube? Often people don't convert the weight of steel into mass by dividing by gravity, or the other way around, they input the value of the mass incorrectly. I had that problem myself when I was originally working on the beam modes by hand. Fortunately, with Tom's worked example, I could verify I had the right units on my mass term.
The FE programs I used made it difficult to set up the boundary conditions. I was never able to get a free-free mode. As a result, I had to either work on the PDE or look up solutions. I don't like looking up solutions because there is a good chance you miss something in the assumptions. What I prefer to do is derive the expression and then look it up to see if I got it right.
But since you have access to a nice FE program ...
My next question will be, how can I tune the chime to a precise frequency?
What I want to do is be able to take a specific diameter tubing, like the fence post, and make a whole scale from the same stuff. Well, at first some may say, no problem. Just cut the tube to the different lengths and you will get the notes you want. Since I support the acoustic mode (resonating air column) theory right now, the tube will only match the acoustic mode at discrete frequencies.
Anyway, my theory is that you can place a mass like a large hex nut on the end (top) and that will change the frequency of the beam mode. If the upper six inches of the tube were threaded, you could move the nut up or down to bring the tube into tune.
Let me know what you think of tuning a chime in this way.
I suspect that the reasons for the frequency ratios not following the theory precisely are due to the shear deformation effects that Greg mentioned and also the effects of rotatory inertia. Normally these effects can be ignored for long thin beams with a wavelength to thickness ratio of >10:1. Tom's beam has a wavelength to diameter ratio of about 12:1 for the 4th mode.
However, we have a thin walled tube with a correspondingly lower shear stiffness and larger radius of gyration than for a same-sized solid beam which means that these secondary effects could be noticeable.
Using a Timoshenko beam model instead of a Euler-Bernoulli model should take into account these differences. I suspect that Greg's FE model will show a similar deviation from the Den Hartog formula.
I recently got S. Rao Vibration 3rd ed vibration textbook used for $20 to supplement my low-budget library of mechanical and vibration books. I saw where he talked about Tomshenko beam theory. I was looking for the punchlines (simple formula to plug and chug) but couldn’t find it. A little over my head I think.
I have a critical speed analysis program which uses the transfer matrix method. It allows to specify a hollow shaft with no bearings and free/free end conditions. It also allows to exclude gyroscopic effects. Critical speed of a hollow shaft excluding gyroscopic effects would be the same as the bending modes that we’re talking about, wouldn’t it?
Note the program also allows to include or exclude shear effects.
Would be interesting to try it out when I get time... probably not until the weekend.
As far as acoustic coupling to the tube is concerned, it is possible to excite combined acoustic modes, such as the 1T-1L mode (1st tangential and 1st longitudinal mode combined), etc. This should result in possible acoustic resonances at frequencies between the 1T and 1L frequencies IIRC. It seems likely to me that a tangential acoustic(think "slosh") mode or combined slosh+longitudinal acoustic mode could couple to beam bending motions more so than coupling between pure longitudinal acoustics modes and beam bending modes. Damn, that was a hard sentence to write, and it still doesn't sound good... hopefully you get the idea.
To find the acoustic frequency for combined modes, use the formula
L = sqrt( L1^2 + L2^2)
where L = the combined mode wavelength, L1 = the longitudinal wavelength (is it 2*tube length?), and L2= the tangential mode wavelength, given for the 1st order slosh mode by:
L2 = pi * D / 1.841,
where D is the cylinder diameter.
The combined mode frequency is then given by the equation f = c/Lt, c is the speed of sound, and L is the combined mode wavelength.
I agree, the modes wouldn't couple very efficiently, and the tangential mode contribution would be pretty highly damped within a few wavelengths down the tube. Just was looking at the prior post that was questioning the discrepancy between apparent resonant frequency and the beam bending frequency, and suggested that some combined mode coupling could explain some of the apparent frequency shift. Also, was trying to picture how a coupling mechanism between beam bending and a longitudinal mode might occur, so suggested the above. Wouldn't trust what I wrote without some acoustic pickup data to back it up.
Dinosaur, forgive and ignore my earlier post, it's just a comment from the peanut gallery. This thread is quite interesting, and it will be pretty neat to see if acoustic/structural coupling (i.e. tuning the tubes to produce a beam bending mode that is very close to the longitudinal acoustic mode) will produce an audible/noticeable change to the human ear. Good luck and keep us posted, please.
I drilled a hole in the 0.94 inch tube yesterday and cut it down to 58.5 inches long. I hung the tube on the wall in my shed (sure wish I had a shop) and struck it. At 58.5 inches, it was supposed to be tuned to both the third beam mode and the third acoustic mode. I couldn't hear any substantial difference in the tone quality from the 63 inch tube before I cut it down.
However, I did note that the hanging mechanism played a significant role in the chime behavior. When the chime tube was resting on only one side of the two holes, it "rang" better (clearer and more sustained). But when I balanced it better so it rested on both holes, the sound dampened out much more quickly and did not have as clear a "ring".
I am not ready to declare anything concerning the merits of coupling the longitudinal acoustic mode with the transverse beam mode. The problem of the chime support and the fact that I started with a third mode (which probably doesn't contain much energy) while hanging the tube from the first mode node (say that five time fast) indicates more testing is required. Maybe I will get a chance to try a couple more this weekend.
Interesting results. Just one question. Did you try striking in a direction perpendicular to the line formed by the two support holes. That would allow movement where the support acts like a true pivot, whereas if you struck 90 degrees from there you could get a reaction moment from the support.
Also just thinking out loud, I'm wondering whether the type of string used to support the chime makes a difference. My intuition would tell me a rubber band would be a bad support material and fine metal bailing wire would be good. String might be in between. It seems like a lot of the cheap small chimes I've seen used fishing line for some reason.
Well, I did some tests last night with the 0.94 inch dia conduit.
But first ... My suspension is a galvanized nail through a hole drilled through both sides. The nail is supported on each side by cotton string because that is what I had laying around the shed. I struck the tube from the "front", perpendicular to the axis of the nail, and from the "side", parallel to the axis of the nail, as well as at points near the top and the middle and the bottom. Striking the tube from the front was noticably better than striking the tube from the side and I agree it is for the reasons electricpete stated. Another important observation is that striking the chime near a node of the first mode shape produced poor results. I ended up striking the tube at about 10% L from the bottom with an oak dowel. I also noticed that when I struck the tube with the end of the dowel I had better results than when I struck it with the side of the dowel.
Now for the results of my experiments last night ...
The first night I had cut the tube to about 54.5 inches which was computed to match the third beam mode and the third acoustic mode. The ring was not great but it was not bad. Last night, I cut the tube to 45 inches which was predicted to match the second beam mode and nearly the third beam mode also with the second acoustic and fourth acoustic modes respectively. The ring was about the same quality as the first test and it sounded either about the same pitch or lower.
I know several guys will raise their eyebrows at that but remember the first length was computed to resonate at the third beam mode, a higher frequency than the second test at a second beam mode. However, because I didn't record the sounds, I am not sure what frequencies I was hearing.
Next I cut the tube to about 33 inches which was computed to be about one-quarter inch longer than the matching first beam mode with the first acoustic mode. This chime had a noticably poorer sound than the first two. It had less sustain and a harsher ring sound. But, the first beam mode at this length has a lower frequency than the second beam mode or third beam mode of the earlier experiments.
Now I am beginning to have doubts about the importance of acoustic modes. I am also beginning to think that there is something about the longer tubes that makes them more suitable. As a matter of fact, I am beginning to think it may have to do with the amount of striking energy that is stored in the tube as vibration energy.
When I hit the tube, it vibrates. But, it also swings. So I have vibration energy, swinging pendulum energy and I suppose some energy of deformation lost in the oak striker. The pendulum energy is lost for the purposes of hearing any sound. The shorter chime has a comparatively small mass so it swings more as you would expect, but it also has an even greater reduction in polar moment of inertia. Now instead of just swinging, it also kinda bobs up and down. I think this is part of the reason my third chime was so poor.
I did a final test after cutting one-quarter inch off the tube to get it to match the first mode frequency, but the results were much the same.
My theory at this point is that I want to work with longer chimes for the energy reasons mentioned previous. Also, if possible, I hope to get a chime that resonates at the combined second and third modes. In a few days, I will have time to experiment with the galvanized fence posts with an O.D. of about 1.52 inches and a wall thickness of 0.068 inches. The tube is 72 inches long right now. I am also considering testing this tube with a hang point at the second beam mode node which I think is around 13% L. If anyone knows the location of this node, please let me know.
If anyone is interseted in doing their own experiments, it turns out that it is not that difficult to cut the tube with a hacksaw. After I cut it to length, I take a file and round off the edge a bit for safety. My son likes to hang around me when I am working and I don't want him to cut himself in his curiosity.
It seems reasonable for whatever reason it is not always the 1st or 2nd or 3rd mode that is dominant... changes when we change the pipe size. That can be seen on Tom's data - in Chime 1 the first mode is dominant, while in chimes 3,4,5 the 2nd mode is dominant (at least for the first 5 seconds).
The reasons why the dominant mode may change? - One may be air column resonance. - Another may be the support location which favors certain modes (when it falls on a node) and suppreses others. One more way might be the ability/inability of the striker to excite high frequencies. The curves I see for hammers used in bump tests have flat response for low frequencies, and when frequency exceeds a certain cutoff they begin to tail off. A harder tip generally has a higher cuttoff. So if you decrease the lenght which moves one of the modes above the range which you can excite, the absence of that mode could make a new lower mode may become dominant. I think the tip of your dowel acts harder than the center of the dowel so you are more successful at exciting high frequencies with the tip of yor dowel.
There was nothing new in my discussion (all of these factors you've discussed before). Just wanted to throw in some comments.
If you want to drag the chime into your study, you can record the sound into your pc microphone (or buy one for $2 if you don't have one) to create a wave file which can be analysed for pitch using a wide variety of free tools from excel to cooledit. I have just started messing around with scilab which looks like a pretty powerful free version of matlab. Or if you'd like to email me any files I'd be glad to send you back a spectrum.
I guess for completeness a 4th factor which could affect which mode is dominant is the location of a strike (is it near a node or an anti-node of a particular mode).
I programmed the transfer matrix method in scilab.
As I increased the number of segments, the solution converged to the beam solution. I guess I should have known that - the underlying math of the method is the beam assumption. The strength of that method would be in analysing beams/shafts that have changes in cross section and one or more springy supports (bearings) along their length. Not a smart tool to apply to the chime problem which can be solved exactly (to within the same assumptions) using the beam formla. But at least now I have a good test case to verify my program.
Start A New Thread
DESCRIPTION: Mechanical Acoustics/Vibration engineering technical support forum and mutual help system for engineering professionals. Selling and recruiting forbidden.
