Control Valve Capacity Testing
What differences can I expect in results from running the ISA S75.02 valve capacity tests (compressible - air) under vacuum (e.g. downstream “blowing engines”) versus pressurized (e.g. upstream air compressor)?
Thank you in advance for your input!
RE: Control Valve Capacity Testing
If in both cases (vacuum & pressurized) DP/P1 is .02 or less should I expect any difference in the test results and ultimately in the calculation of Cv?
I currently have this situation, different values for Cv on the same set of valves. The only obvious difference is the vacuum versus pressurized test condition. I am trying to determine the cause of the discrepancy.
Thanks again.
I wouldn't think so.
Can you retest the valves? I am thinking you have experimental scatter. How much do they differ? The Cv equation for gases should be calculated in absolute units. Make sure you are not using Gage units.
Cv tests run on air can be a bit tricky. As Jim mentioned, make sure you are using absolute pressures. Also, verify that your flow rate measurements are accurate enough. You won't have much flow at x=0.02 and less.
Your two setups should not matter if you have accurate flow rate and pressure measurements and you are using absolute pressures.
The value of Dp/Pi which causes choked flow is a function of Xt and also the gas's ratio of Cp/Cv.
