Calculating over-bend for sheet metal (Catia V5R15)
Hi guys, I need to bend some sheet metal. Is there an add-in or other program with which one can calculate the extra bend needed. eg. 90° angle 2mm thk result, would need to be bent at 92° to end up as required.
Any help will do.
Thanks, Gary.
Any help will do.
Thanks, Gary.
RE: Calculating over-bend for sheet metal (Catia V5R15)
http://www
Derek
http://www
