How to create a surface by boundary in NX3
Does anybody know how to (easy and fast create) a rectangular surface out of a set of curves? In I-deas there was this option 'surface by boundary'. I there a similar command in Nx3, except 'Through curves'?
Kind regards,
Roy Munnichs
RE: How to create a surface by boundary in NX3
Hi Munnichs
Is the surface planar? If so go INSERT-SURFACE-BOUNDED PLANE.
If not planar then 'Through curve mesh' should do the trick.
INSERT-MESH SURFACE-THROUGH CURVE MESH.
Thanks, this is exacly what I want.
But then there is another issue: why can't find this option in the 'surface' toolbar?
Kind regards,
Roy Munnichs.
They have started hiding many command incons so that you have to manually add them to your toolbars as you need them.  It seems counter-intuitive to me, especially for newer users.
Bounded Plane is on the Form Feature toolbar, at least up to NX3.
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
Bla bla bla...
Insert->Mesh Surface->N-Sided Surface, then choose the boundary from curves, etc
It`s simplier than Through Curve Mesh
cad - designer
i-deas 11nx  sworks 2006   ug nx 4.0
IMB InteliStation M Pro
Blah blah blah my ass....
It's simpler to create an N-Sided surface but N-Sided surface doesn't provide nearly the amount of control that Through Curve Mesh does.  N-sided Surface is a niche command that is not a do-all surface creator like Through Curve Mesh can be.
Try matching the middle of an N-sided surface to a profile or curve...you can't.  However, you can just add the curve to a TCM mesh and be done with it.
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
Tim,
Well said.
I just didn't care too much for the "blah blah blah" crap that was posted.  Not a very good idea to post something like that when he might be the one needing our advice in the future.  I know that I won't be offering any of my "blah blah blah" to him should he be needing help.
I also have a feeling we won't need to worry about it because he probably won't be here very much longer.thumbsup2
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
