Orthotropic Materials..."Error Message"
I have typed in all the elastic stiffness parameters for Orthotropic material.  I submitted my job for analysis and an error occur saying that:
Anisotropic material properties without local oreintation system have been defined for 2460 elements. Anisotripic material properties must be defined in a local orientation system.  The elements are identified in element set ErrElemAnisotropicMaterial.
Can anyone give any insight into this problem
RE: Orthotropic Materials..."Error Message"
You need to assign an orientation for the orthotropic material (i.e. to define a local coordinate system). The orthotropic material properties are assumed to be given with respect to this material orientation system.
You can define/assign an orientation system to the material in  "Property" section of ABAQUS/CAE, or, by using ORIENTATION keyword, if you write the input file by yourself.
For details and usage see:
ABAQUS/CAE User's Manual:
16.9.3 Assigning a material orientation
and:
ABAQUS Analysis User's Manual
2.2.5 Orientations
