Tangent assy. constraint?
I have an assembly, which has an o-ring positioned in a c'sing (Cone shape).
How do I assy the o-ring into the c'sink so that it is tangent to the c'sink surface?
RE: Tangent assy. constraint?
2 constraints needed. first constrain the axis of the cone shape to the axis of the o-ring. next constraint will be a surface contact constraint from the cone shape to the o-ring
Derek
I just wanted the oring to stay tangent to the c'sink if there were dimensional changes to a part.
On the o'ring create a reflect line with the angle value of the cone. create a point on this curve.
Then coincidence between point and cone surface.
