Connect two macros...how?
Hello. I create two macros.First identify selected surface and give some information about it and second macro identify selected line and give some information about it.So I want connect this macros in one that if I select surface then identify it give information about it and give information about it boundary line(macro identity line). How I can make something like that???I work with API SolidWorks not so long and I dont have any ideas for this problem.If You have please answer.
First macro:
Option Explicit
Sub main()
Dim swApp                   As SldWorks.SldWorks
Dim swModel                 As SldWorks.ModelDoc2
Dim swSelMgr                As SldWorks.SelectionMgr
Dim swFace                  As SldWorks.Face2
Dim swSurf                  As SldWorks.Surface
Dim boolstatus              As Boolean
Dim longstatus              As Long, longwarnings As Long
Dim Feature                 As SldWorks.Feature
Dim MathPoint               As SldWorks.MathPoint
Dim RefPoint                As SldWorks.RefPoint
Dim vRefPointFeatureArray   As Variant
Dim XYZ                     As Variant
Dim vPlane                  As Variant
Dim vCylinder               As Variant
Dim vCone                   As Variant
Dim vTorus                  As Variant
Dim vSphere                 As Variant
Dim vBsurf                  As Variant
Dim vRefPoint               As Variant
Set swApp = Application.SldWorks
Set swModel = swApp.ActiveDoc
Set swSelMgr = swModel.SelectionManager
Set swFace = swSelMgr.GetSelectedObject5(1)
  If swSelMgr.GetSelectedObjectCount <> 1 Then
  swApp.SendMsgToUser " Please select ONE Surface to identify "
   GoTo CleanUp
   End If
Set swSurf = swFace.GetSurface
vRefPointFeatureArray = swModel.FeatureManager.InsertReferencePoint(4, 0, 0.01, 1)
Set Feature = vRefPointFeatureArray(0)
Set RefPoint = Feature.GetSpecificFeature2
Set MathPoint = RefPoint.GetRefPoint
XYZ = MathPoint.ArrayData
Set MathPoint = Nothing
Set RefPoint = Nothing
Set Feature = Nothing
 swApp.SendMsgToUser " Center of selected surface: " _
 & vbCrLf _
 & vbCrLf & " X = " & XYZ(0) * 1000 & " mm" _
 & vbCrLf & " Y = " & XYZ(1) * 1000 & " mm" _
 & vbCrLf & " Z = " & XYZ(2) * 1000 & " mm"
 If swSurf.IsPlane Then
   vPlane = swSurf.PlaneParams
   swApp.SendMsgToUser " Selected Surface - PLANE " _
   & vbCrLf & vbCrLf & " Normal  = (" & vPlane(0) & ", " & vPlane(1) & ", " & vPlane(2) & ")" _
   & vbCrLf & vbCrLf & " Root    = (" & vPlane(3) * 1000# & ", " & vPlane(4) * 1000# & ", " & vPlane(5) * 1000# & ") mm" _
   & vbCrLf & vbCrLf & " File    = " & swModel.GetPathName
  GoTo CleanUp
  End If
 If swSurf.IsCylinder Then
 vCylinder = swSurf.CylinderParams
 swApp.SendMsgToUser " Selected Surface - CYLINDER " _
 & vbCrLf & vbCrLf & " Radius  = " & vCylinder(6) * 1000# & " mm" _
 & vbCrLf & vbCrLf & " Axis     = (" & vCylinder(3) & ", " & vCylinder(4) & ", " & vCylinder(5) & ")" _
 & vbCrLf & vbCrLf & " Origin  = (" & vCylinder(0) * 1000# & ", " & vCylinder(1) * 1000# & ", " & vCylinder(2) * 1000# & ") mm" _
 GoTo CleanUp
 End If
 If swSurf.IsCone Then
 vCone = swSurf.ConeParams
 swApp.SendMsgToUser " Selected Surface - CONE " _
 & vbCrLf & vbCrLf & " Radius      = " & vCone(6) * 1000# & " mm" _
 & vbCrLf & vbCrLf & " Half angle  = " & vCone(7) * 57.3 & " degrees" _
 & vbCrLf & vbCrLf & " Axis        = (" & vCone(3) & ", " & vCone(4) & ", " & vCone(5) & ")" _
 & vbCrLf & vbCrLf & " Origin      = (" & vCone(0) * 1000# & ", " & vCone(1) * 1000# & ", " & vCone(2) * 1000# & ") mm" _
 GoTo CleanUp
 End If
 If swSurf.IsTorus Then
 vTorus = swSurf.TorusParams
 swApp.SendMsgToUser " Selected Surface - TORUS " _
 & vbCrLf & vbCrLf & " Distance betwen center of torus and center of revolved circle = " & vTorus(7) * 1000# & " mm" _
 & vbCrLf & vbCrLf & " Radius of revolved circle  =  " & vTorus(6) * 1000# & " mm" _
 & vbCrLf & vbCrLf & " Center  =  (" & vTorus(0) * 1000# & ", " & vTorus(1) * 1000# & ", " & vTorus(2) * 1000# & ") mm" _
 & vbCrLf & vbCrLf & " Axis     =  (" & vTorus(3) & ", " & vTorus(4) & ", " & vTorus(5) & ")" _
 & vbCrLf & vbCrLf & " File     =  " & swModel.GetPathName _
 & vbCrLf & vbCrLf & " Major Radius of the torus  =  " & vTorus(6) * 1000# + vTorus(7) * 1000# & " mm  ???"
 GoTo CleanUp
 End If
 If swSurf.IsSphere Then
 vSphere = swSurf.SphereParams
 swApp.SendMsgToUser " Selected Surface - SPHERE " _
 & vbCrLf & vbCrLf & " Center   = (" & vSphere(0) * 1000# & ", " & vSphere(1) * 1000# & ", " & vSphere(2) * 1000# & ") mm" _
 & vbCrLf & vbCrLf & " Radius   = " & vSphere(3) * 1000 & " mm" _
 GoTo CleanUp
 End If
 If swSurf.IsBlending Then
 swApp.SendMsgToUser " Selected Surface - BLEND "
 GoTo CleanUp
 End If
 If swSurf.IsSwept Then
 swApp.SendMsgToUser " Selected Surface - SWEPT "
 GoTo CleanUp
 End If
 If swSurf.IsRevolved Then
 swApp.SendMsgToUser " Selected Surface - REVOLVED "
 GoTo CleanUp
 End If
 If swSurf.IsForeign Then
 swApp.SendMsgToUser " Selected Surface - FOREIGN "
 GoTo CleanUp
 End If
 If swSurf.IsOffset Then
 swApp.SendMsgToUser " Selected Surface - OFFSET "
 GoTo CleanUp
 End If
 If swSurf.IsParametric Then
 swApp.SendMsgToUser " Selected Surafce - B-SPLINE SURFACE "
 GoTo CleanUp
 End If
CleanUp:
    Set swFace = Nothing
    Set swSurf = Nothing
    Set swSelMgr = Nothing
    Set swModel = Nothing
    Set swApp = Nothing
End Sub
Second Macro:
Option Explicit
Const dPi = 3.141592654
Const MtoMM = 1000
Const M2toMM2 = 1000000
Const swSelEDGES = 1
Const swMbInformation = 2
Const swMbStop = 4
Const swMbOk = 2
Dim swModel As ModelDoc2
Dim swSelMgr As SelectionMgr
Dim swEdge As Edge
Dim swCurve As Curve
Dim lngSelType As Long
Dim pt1 As Double
Dim pt2 As Double
Dim vpoint1 As Variant
Dim bVal1 As Boolean
Dim bVal2 As Boolean
Dim vSafeArray As Variant
Dim dLen As Double
Dim vParams As Variant
Sub main()
    Dim sMsg As String
    Set swApp = CreateObject("SldWorks.Application")
    swApp.SendMsgToUser2 "Please Select ONE Edge to Measure", swMbStop, swMbOk
    GoTo CleanUp
    End If
    lngSelType = swSelMgr.GetSelectedObjectType2(1)
    If lngSelType = swSelEDGES Then
        Set swEdge = swSelMgr.GetSelectedObject3(1)
        Set swCurve = swEdge.GetCurve
        If swCurve.IsLine Then
        Call swCurve.GetEndParams(pt1, pt2, bVal1, bVal2)
        dLen = swCurve.GetLength2(pt1, pt2)
        vParams = swEdge.GetCurveParams
        sMsg = "Selected Edge - Line" & vbCrLf & vbCrLf & _
        "Length = " & Format(dLen * MtoMM, "###,##0.000") & " mm" _
        & vbCrLf & "Coordinates End Point1 : (" & Format(vParams(0) * 1000, "##,##0.000") & ", " _
        & Format(vParams(1) * 1000, "##,##0.000") & ", " _
        & Format(vParams(2) * 1000, "##,##0.000") & ")" & "" _
        & vbCrLf & "Coordinates End Point2 : (" & Format(vParams(3) * 1000, "##,##0.000") & ", " _
        & Format(vParams(4) * 1000, "##,##0.000") & ", " _
        & Format(vParams(5) * 1000, "##,##0.000") & ")" & "" _
        & vbCrLf & "Start Point = " & Format(vParams(6) * 1000, "##,##0.000") & " mm" _
        & vbCrLf & "End Point = " & Format(vParams(7) * 1000, "##,##0.000") & " mm"
        End If
      If swCurve.IsCircle Then
      vSafeArray = swCurve.CircleParams
      sMsg = "Selected Edge - Circle" & vbCrLf & vbCrLf & _
      "Center : (" & Format(vSafeArray(0) * MtoMM, "##,##0.000") & _
      ", " & Format(vSafeArray(1) * MtoMM, "##,##0.000") & _
      ", " & Format(vSafeArray(2) * MtoMM, "##,##0.000") & ")" & " (mm)" & vbCrLf & _
      "Diameter = " & Format(vSafeArray(6) * 2 * MtoMM, "##,##0.000") & " mm" & vbCrLf & _
      "Circumference = " & Format(2 * dPi * vSafeArray(6) * MtoMM, "##,##0.000") & " mm" & vbCrLf & _
      "Area = " & Format(dPi * vSafeArray(6) ^ 2 * M2toMM2, "##,##0.000") & " mm²"
      End If
      If swCurve.IsBcurve Then
      sMsg = "Selected Edge - Bcurve" & vbCrLf & vbCrLf & _
      "Length = " & Format(dLen * MtoMM, "##,##0.000") & " mm" _
      & vbCrLf & "Coordinates End Point1 : (" & Format(vParams(0) * 1000, "##,##0.000") & " ,  " _
      & Format(vParams(1) * 1000, "##,##0.000") & " ,  " _
      & vbCrLf & "Coordinates End Point2 : (" & Format(vParams(3) * 1000, "##,##0.000") & " ,  " _
      & Format(vParams(4) * 1000, "##,##0.000") & " ,  " _
      End If
     If swCurve.IsEllipse Then
     vSafeArray = swCurve.GetEllipseParams
     sMsg = "Selected Edge - Ellipse" & vbCrLf & vbCrLf & _
     "Center of ellipse : " _
     & vbCrLf & "        X = " & Format(vSafeArray(0) * MtoMM, "##,##0.000") & " mm" _
     & vbCrLf & "        Y = " & Format(vSafeArray(1) * MtoMM, "##,##0.000") & " mm" _
     & vbCrLf & "        Z = " & Format(vSafeArray(2) * MtoMM, "##,##0.000") & " mm" _
     & vbCrLf & vbCrLf & "Major Radius = " & Format(vSafeArray(3) * MtoMM, "##,##0.000") & " mm" _
     & vbCrLf & "Minor Radius = " & Format(vSafeArray(7) * MtoMM, "##,##0.000") & " mm" _
     & vbCrLf & "Area = " & Format(dPi * vSafeArray(3) * 2 * vSafeArray(7) * 2 * M2toMM2, "##,##0.000") & " mm²" _
     & vbCrLf & "Circumference ??? = " & Format(dPi * (3 * ((2 * vSafeArray(3) + 2 * vSafeArray(7)) / 2 - (2 * vSafeArray(3) * 2 * vSafeArray(7)) ^ 0.5) * MtoMM), "##,##0.000" & " mm")
     End If
    Else
    swApp.SendMsgToUser2 "I can only measure Edges", swMbStop, swMbOk
    End If
    swApp.SendMsgToUser2 sMsg, swMbInformation, swMbOk
CleanUp:
    Set swEdge = Nothing
    Set swCurve = Nothing
    Set swApp = Nothing
End Sub
RE: Connect two macros...how?
Cannot you just combine the macros into one?
I don't see why you can't just cut-and-paste code from one into the other.  Just be sure you do not double the difinitions of your variables, especially object variables.
Do yourself and the next programmer a big favor: break your macro up into smaller subroutines and functions.  I would probably write separate subs or functions to 1.) verify proper selection and determine selected object type; 2.) get object information; 3.) display information 4.) clean up.
Good job adding "Cleanup" steps to your program.  Very important to release objects (set objects to "Nothing").  I usually put cleanup commands into a subroutine and call at the end.
Instead of message box, I would display information on a form and allow user to copy data to paste elsewhere.
I could be the world's greatest underachiever, if I could just learn to apply myself.
http://www.EsoxRepublic.com-SolidWorks API VB programming help
The reason he can't cut and paste is that the two macros have different initial conditions.  For the first, a surface/face must be selected prior to running.  For the second, an edge must be selected.  If I understand correctly, what picia would like to do is select the face and run the one macro that will give him the face data and the data on its bounding edge(s).
Picia:
What you need to do is copy macro # 2 into the same macro file as #1.  Instead of "main()", macro # 2 should be something like "myEdgeData(swEdge as SldWorks.Edge)".  What you will do is call the second macro from the first, passing it a reference to each edge bounding the face.  You can do this by placing some code like this toward the end of macro # 1
dim myEdges() as variant
dim i as long
myEdges = swFace.getedges
for i = 0 to swface.getedgecount-1
   call myEdgeData(myEdges(i))
next i
You will have to remove all the code from macro #2 that gets the selected edge, since the edge will be passed by macro #1.
hello.
I would like something like that what wrote handleman.oh, handleman thanks for your help.I place this code to the end of macro 1, copy code from macro and if I want run i have a error: Type of argumet ByRef incopatibility. And myEdges(i) is highlighted...
Dim myEdges As Variant
Dim i As Long
myEdges = swFace.GetEdges
For i = 0 To swFace.GetEdgeCount - 1
   Call myEdgeData(myEdges(i))
Next i
End Sub
Sub myEdgeData(swEdge As SldWorks.Edge)
Picia:
Enjoy!
CODE
Sub main()
Dim XYZ                     As Variant
Dim i                       As Long
    GoTo CleanUp
End If
    & vbCrLf _
ElseIf swSurf.IsCylinder Then
ElseIf swSurf.IsCone Then
ElseIf swSurf.IsTorus Then
ElseIf swSurf.IsSphere Then
ElseIf swSurf.IsBlending Then
ElseIf swSurf.IsSwept Then
    GoTo CleanUp
ElseIf swSurf.IsRevolved Then
    GoTo CleanUp
ElseIf swSurf.IsForeign Then
ElseIf swSurf.IsOffset Then
ElseIf swSurf.IsParametric Then
End If
If swFace.GetEdgeCount > 0 Then
    swApp.SendMsgToUser swFace.GetEdgeCount & " edges found"
        myEdges(i).Select False
        Call MyEdgeData(myEdges(i), swApp)
    Next i
Else
    swApp.SendMsgToUser "The face has no edges"
End If
swFace.Select False
CleanUp:
    Set swApp = Nothing
End Sub
Sub MyEdgeData(ByVal swEdge As SldWorks.edge, ByVal swApp As SldWorks.SldWorks)
Const MtoMM = 1000
Const swMbStop = 4
Const swMbOk = 2
Dim pt1 As Double
Dim pt2 As Double
Dim dLen As Double
Dim sMsg As String
    sMsg = "Selected Edge - Line" & vbCrLf & vbCrLf _
        & "Length = " & Format(dLen * MtoMM, "###,##0.000") & " mm" _
End If
End If
End If
End If
CleanUp:
End Sub
Oh yeah!That is that what I need!Thanks handleman for your great help!!!
With a little tinkering, this macro could be made more robust by adding a userform with the objects fed into a listbox where the user can choose which object to get information on...with the info displayed in a label next to it (instead of a separate msgbox popping up).
