ansys nomber of nodes
hi
I need to set as a parametr nomber of nodes could you help me
x=nomber of nodes; how to do it in APDL
RE: ansys nomber of nodes
*GET,NoNodes,NODE,0,COUNT
is eqv to NoNodes= Total number of selected nodes
The *get command is the most powerful ANSYS APDL command!
Always look in the help (help,*get)!
You can get a lot (almost all) informations of ANSYS database with the *get command!
*get,n_num,node,,count !count of nodes
*get,n_max,node,,num,max !maximum node number (selected)
*get,n_maxd,node,,num,maxd !maximum node number (defined)
