Flexible Pipe Stress Checks
Can someone explain how Von Mises stress is calculated for flexible pipes.
The internal carcass will contain pressure so I'm guessing that this will be used to find hoop stress. However, the other layers will contribute to bending and axial stress...
I'm checking a flexible which is being used for tie-in to a rigid platform. Tension and MBR checks should be straightforward, but I need advice re VM checks.
Any pointers welcomed.
RE: Flexible Pipe Stress Checks
Do you really mean the pressure vault which lies between the liner and the armour layers?
My understanding is that you need to model each layer separately in a FE model. Then apply the pressures, moments and forces.
The stresses in the armour wires must be FE modelled in order to establish the VM stress, taking into account the interactions between the different layers and the elements of pressure (internal and external), bending and tension in the pipe. small scale models should be validated against more complex 3D full scale (full pipe) models and preferably test data.
Suggest you contact one of the manufacturers (Technip / Wellstream / NKTF) or an independent such as Marintek who have their own BFLEX model for flexible pipes.
Riadsala
