Composite Deck
Composite Deck
Good Evening everyone:
I need a reference book or find information in designing a composite deck floor system using steel bar joist and concrete reinforced slab. Can anyone lead me in the right direction? Any information provided will be deeply appreciated.
Thank You
Kmat
Thank You
Kmat
RE: Composite Deck
Typically with 1-1/2" deck and 4" total thickness 2-1/2 conc and 1-1/2 deck, you can span 6 or 7 feet. It is then a matter of designing the joists accordingly.
It is also possible to space the joists at 2 or 2-1/2 feet o/c and use a material called V-rib form with 2-1/2" or 2" concrete topping.
RE: Composite Deck
Thanks for the reply dik
Kmat
RE: Composite Deck
Dik
RE: Composite Deck
Peace
Kmat
RE: Composite Deck
Dik
