laptop to siemens s7 200 cable
Was wondering exactly what I need to hook my laptop to an s7 200.  DB9 connector on plc and ethernet and usb on my laptop.  Was wondering if anyone knows a way to convert the ethernet port over to a standard serial port on the computer?
RE: laptop to siemens s7 200 cable
Have a look at www.process-informatik.de
They have ethernet interfaces that will work with the S7 software and plug into the programming port on the S7 200 or S7 300 PLC.
You connect your laptop via a hub or ethernet cross over cable.
GOOGLE "Device Server"
B&B stock many
Buy.com is the cheapest
