Serial data from PLC to file, is VB the tool ?
Hi, as a PLC programmer with no (yet) experience of VB, I could do with some guidance. I have an app to develop that will take an ASCII text string (from a PLC) from the serial COM port and save it as a file, the file name being sequentially numbered (0000-9999) with a .prd extension. Once at 9999, the filename reverts to 0000 and over-writes the old files.
One text string in on the COM port approx every 5 minutes.
RE: Serial data from PLC to file, is VB the tool ?
VB has a serial port communication tool (MSCOMM control) which takes serial data into your program. Saving a file and incrementing your file name are also very straightforward
Good Luck
johnwm
________________________________________________________
To get the best from these forums read FAQ731-376 before posting
Steam Engine enthusiasts: www.essexsteam.co.uk
