rotary deburrig tool
Any one know of a pneumatic deburring tool like this (see link) that isn't actuated by a hand lever? I'd like the same style but to acuate it via a solenoid valve signaled by a robot. The robot will present the part to a degating fixture. Google has not been helpfull.
htt p://www.dy nabrade.co m/cgi-bin/ Industrial /51300?aFG gv39d;;116
htt
Grant
Applications Engineer
SW2006 SP 3.4
IBM InteliStation Pro M
P4 3.4 GHz, 2GB RAM
XP Pro SP2.0
NIVIDA Quadro FX 1100
RE: rotary deburrig tool
a clamp so that the hand lever is pushed-in or
use duct-tape to disable it or
take it apart and fix the valve into open position or
Tie the lever to the body temporarily with e.g. tape
and inject epoxy to fix it in this pos\ition. After
the epoxy sets, you can cut off the handle.
Plesae read FAQ240-1032
WEB: <http://geocities.com/nbucska/>
TygerDawg
This you might find more appropriate do not need to deal with air solenoid or hose, possibly use output on plc of robot.
http://www.robotcombat.com/marketplace_dewalt.html
