Timing belt clamps/plates?
Has anyone any information on timing belt clamps/plates used for linear motion?
were to buy and also some data sheets/design guides?
thanks in advance people....
RE: Timing belt clamps/plates?
Shaun123,
There are a lot of companies that can supply you with catalogs and engineering information for your application.
Brecoflex makes belts and clamps.  Their catalog and engineering information is on-line:
http://www.brecoflex.com
I hope this helps,
ERT
http://www.akeng.com
thanks ERT for that web site i needed some info on pulleys/belts, lost my notes a while back, thanks again
You can also contact Ametric for a wide selection of all  metric power transmission components. As an importer, they are not held up by manufacturer's production schedules, so supplies are more readily available.
www.ametric.com
Russell Giuliano
thanks for the info guys.
Much appreciated..
