SWDrawingStandardView Constant
I am playing with a VB program that I downloaded through the API help, but I have run into a problem. First off, the program opens a SW assembly, creates a drawing from the assembly. It then cycles through each view to determine the size and rescales it to fit the border that was picked. It will then finish by adding all the details the drawing. Its seems like a very slick program when it works. Now to the error.
When I run the program (see code below), it errors out. I tracked down the problem to an IF statement that is never activated, leaving variable undefined. The original program was written to look for a ViewType of 6 (should match up to SWDrawingStandardView), but a value of 6 is never seen. The first value it sees (Drawing View 1) is Type 7 (SWDrawing NamedView = 7). If I change the IF statement to look for a ViewType of 7, the program works.
Why doesn't it recognize the first drawing view as a standard view?
Here is the code (just for this section): Thanks, Joe
Sub CenterViews()
    Dim Part As SldWorks.ModelDoc2
    Dim View As SldWorks.View
    Dim Sheet As SldWorks.Sheet
    Dim Name As String
    Dim Position As Variant
    Dim PositionMainView As Variant
    Dim MainView As SldWorks.View
    Dim ViewType As Long
    Dim DrScale As Double
    Dim SheetBoundBox As Variant
    Dim CurViewBoundBox As Variant
    Dim ViewsBoundBox As Variant
    Dim FirstView As Boolean
    Dim TitleBlockHgt As Double
    Dim RevBlockHgt As Double
    Dim ViewZoneCenX As Double
    Dim ViewZoneCenY As Double
    Dim ViewsCenX As Double
    Dim ViewsCenY As Double
    Dim DeltaX As Double
    Dim DeltaY As Double
    Dim TemplateBlockHgts As Variant
    Dim MarginY As Double
    Dim ViewsLargerBy As Double
    Dim LocY() As Double
    Dim ViewNo As Long
    Set Part = swApp.ActiveDoc
    'Get the active Drawing Sheet
    Set View = Part.GetFirstView()
    SheetBoundBox = View.GetOutline()
    MarginY = 0.0254   'An extra bit of space
    TemplateBlockHgts = FindTemplateBlockHgts
    TitleBlockHgt = TemplateBlockHgts(0)
    RevBlockHgt = TemplateBlockHgts(1)
    Part.EditSheet
    FirstView = True
    ViewNo = 0
    Set View = View.GetNextView
    Do While Not View Is Nothing
        Name = View.Name
        'Store the y position of each view for later adjustments
        'Later on as the main view is adjusted the dependent views will move
        'along with it - we want to locate them relative to their original positions
        Position = Empty
        Position = View.Position
        ReDim Preserve LocY(ViewNo) As Double
        LocY(ViewNo) = Position(1)
        ViewType = View.Type
        CurViewBoundBox = View.GetOutline()
        'Keep track of the bounding box for all the views combined
        If FirstView Then
            ViewsBoundBox = CurViewBoundBox
            FirstView = False
        Else
            ViewsBoundBox(0) = IIf(CurViewBoundBox(0) < ViewsBoundBox(0), CurViewBoundBox(0), ViewsBoundBox(0))
            ViewsBoundBox(1) = IIf(CurViewBoundBox(1) < ViewsBoundBox(1), CurViewBoundBox(1), ViewsBoundBox(1))
            ViewsBoundBox(2) = IIf(CurViewBoundBox(2) > ViewsBoundBox(2), CurViewBoundBox(2), ViewsBoundBox(2))
            ViewsBoundBox(3) = IIf(CurViewBoundBox(3) > ViewsBoundBox(3), CurViewBoundBox(3), ViewsBoundBox(3))
        End If
        If swDrawingStandardView = ViewType Then
            Set MainView = View
        End If
        ViewNo = ViewNo + 1
    Loop
    'Find the center of the sheet's usable area
    ViewZoneCenX = (SheetBoundBox(2) - SheetBoundBox(0)) / 2
    ViewZoneCenY = (RevBlockHgt - TitleBlockHgt) / 2 + TitleBlockHgt
    'Find the center of the combined views' bounding box
    ViewsCenX = (ViewsBoundBox(2) - ViewsBoundBox(0)) / 2 + ViewsBoundBox(0)
    ViewsCenY = (ViewsBoundBox(3) - ViewsBoundBox(1)) / 2 + ViewsBoundBox(1)
    'Find how much the views need to be moved to center them
    DeltaX = ViewZoneCenX - ViewsCenX
    DeltaY = ViewZoneCenY - ViewsCenY
    'Move the main  view to the center of the sheet's usable area
    Position = MainView.Position
    Position(0) = Position(0) + DeltaX
    Position(1) = Position(1) + DeltaY
    MainView.Position = Position
    'Amount by which the views take up more space
    'than is available between the rev and title blocks
    ViewsLargerBy = (ViewsBoundBox(3) - ViewsBoundBox(1)) - (RevBlockHgt - TitleBlockHgt)
    'If views need to be positioned
    If ((ViewsLargerBy + MarginY + MarginY) > 0) Then
        Set View = Part.GetFirstView() 'The sheet
        Set View = View.GetNextView 'Skip to the first view
        ViewNo = 0
            Position = View.Position()
            If (Position(1) > ViewZoneCenY) Then 'This is an upper view so move it down
                Position(1) = LocY(ViewNo) + DeltaY + (ViewsLargerBy / 2#) - MarginY
            Else 'This is a lower view so move it up
                Position(1) = LocY(ViewNo) + DeltaY - (ViewsLargerBy / 2#) + MarginY
            End If
        ViewNo = ViewNo + 1
        Loop
    End If
    Part.EditRebuild3
End Sub
RE: SWDrawingStandardView Constant
I'm not sure exactly the difference between standard and named views.  Since the program worked for you when you changed to named view you can change the line
to
If (swDrawingStandardView = ViewType) OR (swDrawingNamedView = ViewType) Then
You won't lose the original functionality and, if it's really working fine with swDrawingNamedView, I'd say don't worry about it.
There may have been a change somewhere in SW behavior between the time the API example was written and whatever SW version you're running.  What code is used to create the views?
