plate girder with corner angles
I have seen a plate girder with 25m span, 80cm total height, 5cm X 60cm flanges, 2.5cm X 70cm web. And four corner angles of same dimensions are used at top and bottom of the web. The flanges are made up of 2 2.5cm thick plates which are bolted at certain intervals.... I wonder if the corner angles serve for anything (like connection of flange and the web plates) other than increasing the moment of
inertia of the I beam? I mean; can i use top and bottom cover plates at the place where i need them or use thicker flanges so that i do not need to use corner angles? Is there a problem with connecting the flange and web of the beam only with corner welds? Is there a way of calculation for determining when corner angles should be preffered
instead of thicker flanges?
Another thing that i should mention is that the plate girder is not riveted type girder. The angles are NOT riveted to flange or web. The angles are just welded to flange and the web along ends of their legs. So the flanges are connected to the web with corner welds and welds at the edges of angles.Would there be a problem if i don not use angles at the web - flange connection.
Thanks for your help....
RE: plate girder with corner angles
You can see this type of girders in old railway bridges.
This angle section will be subjected to longitudinal stresses and the horizontal
shear at the junction of web and flange.
rentapen
