Help with MOSFETs
Help with MOSFETs
Using power Mosfet MGSF1N03LT1 (On Semiconductor), the FET takes a long time to turn off (1.2 microsecs.). Why is this?? I need for it to turn off quicker. Any suggestions on different Mosfets that will turn off quicker with the same characteristics as the On Semiconductor part??
swb1
swb1
RE: Help with MOSFETs
TTFN
swb1
Keith Cress
Flamin Systems, Inc.- <http://www.flaminsystems.com>
"It's the questions that drive us"
Keith Cress
You need hi-current driver to drive the gate fast
enough. If the Rout is high, the R*C time constant
will slow it down.
Plesae read FAQ240-1032
WEB: <http://geocities.com/nbucska/>
Repeating the above question... what's your drive circuit like?
FETs need to establish an electric field to control current flow.
As you may remember from physics, the voltage on a capacitor doesn't change instantly, you have to transfer charge for the voltage to change. The more current your driver can source or sink into/out of the gate, the faster the voltage will change on the gate and the faster the FET will turn on/off. There are other parasitic capacitances in the FET as well, but the gate-to-source capacitance is usually the one that lengthens switching time considerably.
swb1
