Memory access vialoation, keeping me from adding a parts list.
How can I fix this issue. Have completed a parts clean up on the assembly file and all loaded parts. Thanks is advance.
RE: Memory access vialoation, keeping me from adding a parts list.
I'm not sure what version your on but I know I used to get that error. I know this is going to sound stupid but give it a try.
After you do the clean up save and exit. Then bring ug and under costomer defaults -->gerenral -->undo (tab)change the undo file size to 4057.
I know this fixed my problem after talking to Gtac
Then bring you parts up and try your parts list again..
Are you using a template parts list. Or are you importing one as a part to a drafting sheet?
Ben Loosli
Sr IS Technologist
L-3 Communications
Something else you could try that works well for me is open a drawing that has your BOM on it already and export a part pick the BOM to be exported. Then in the file you are trying to creat it in import that part containing the BOM.
This is how I always creat my BOM. I've had less errors this way.
