How to create toolpath with cutter diameter compensation with UG
Hi guys,
I am using UG 17, quite an old version. Anyway, I used to generate toolpath with tool centre only. I am now trying to generate toolpath with tool diameter compensation. Can anyone tell me how to do it? Thanks in advance!
RE: How to create toolpath with cutter diameter compensation with UG
Hi I had the same problem
It is possible only in planar profile, machine, cutter compensation and put last small button :)
Will be OK !!!
