Where can i find a stress strain graph of limestone in compession.
I am trying to find as much information about calcium carbonate which forms around the inner surface of the down-hole tubes in oil wells. i hav chosen limestone because there is more information available about limestone in books and internet. but i need to have more information, such as stress strain graphs of limestone (in compression).
RE: Where can i find a stress strain graph of limestone in compession.
Try area universities with Geology departments.  This is a complicated issue.  Rock strength is a function of moisture content, external pressure, temperature, and  a few other things.
This data is well documented by sources like highway departments.  The use of the data is a different issue.
If you just want some general strengths try this:
http://www.stoneinfo.com/astmspecs.html#specs
Rust never sleeps
Neither should your protection
http://www.trent-tube.com/contact/Tech_Assist.cfm
Try searching for Rock Mechanics or mining engineering.  The university that I went to had departments for mining, geology, and petroleum engineering.  It also had a laboratory for rock mechanics.  Thus I would try all these search words along with elastic modulus of limestone.
Qshake
Eng-Tips Forums:Real Solutions for Real Problems Really Quick.
