No load current of asynchronous motors
What percentage of full load current is considered normal for no load conditions in squirrel cage induction motors?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: No load current of asynchronous motors
http://www.micromo.com/03application_notes/appnote2.asp
http://www.micromo.com/09motorgearheadfaqs.asp
http://www.elevatordrives.com/data/files/hpv900_techmanual_tm4090.pdf
etc. for more info.
It appears that the no load current of 20% or less of rated full load current could lead to a very high power factor.
Your suggested links lead to -
a) - A manufacturer of small, special purpose DC motors
b) - The manual for a variable speed drive for elevator applications.
What, precisely, do these links have to do with the question in hand, which relates to the no-load current of squirrel cage induction motors?
Also, note that the power factor at no-load will tend to be be LOW, not high.
On re-reading the above, it comes to me that what you meant was that for a no-load current of 20% or less, the full load power factor would be extremely high (around 0.98). I agree with this, but still question the relevance of the links.
