Saving dgn's as dwg's - curves turn to straight lines - help!
I work in Microstation, but I am often having to save files as dwg's. I've finaly cracked the line weight and line style problem, but there seems to be one more problem that is bothering me!
When I save my files as a dwg, all of my curves and circles turn to straight lines! for example, a circle would look like a hexagon!
Any help would be really appreciated!
Alex
Alex
RE: Saving dgn's as dwg's - curves turn to straight lines - help!
This sounds like your display resolution setting is too low in AutoCad. In Autocad, under tools/options/display, set the display resolution to 1000 or higher. That should smooth out the segmented circles.
Mike
