Tiling smaller sheets for printing/taping together larger pages
Hi folks,
In AC 2006...
I need to plot a series of drawings to at least four 8.5 x 11 standard sheets in order to have a larger print. TurboCad has this feature in the Print dialogue, but I don’t use TC any more. My standard HP home laser printer has the option to do “poster” settings by printing one quarter of the drawing onto four separate sheets, BUT, I must trim a quarter inch off each page in order to get the pages to line up.
I am hoping some one has a suggestion for me… one in which four sheets can be printed and simply taped together without the trimming off edges
Or, how to split the drawing into four equal, exact sections… a viewport for each… then print??? If so, how?
Thank you!
Paul
In AC 2006...
Thank you!
Paul
RE: Tiling smaller sheets for printing/taping together larger pages
IMHO, I don't think ACAD can split a large sheet. You have to do that manually in the paperspace.
But I would try to make a *.dwf. The Autodesk Express Viewer can split the drawing.
Or, maybe better, plot Your drawing as a *.pdf-file and try to split the sheet with Adobe...
Tested with ADT2004, AA prof., metric.
Lothar
ADT 2004
ACAD 2002
