Low Pressure to High Pressure thru Venturi
Low pressure flow 100 gpm pressure 20 psi
High pressure flow 2000 gpm pressure 100 psi
Is it possible to inject the low pressure flow into the high pressure flow using a Venturi unit? No booster pump available. How to do the calculation?
A real problem.
A real problem.
RE: Low Pressure to High Pressure thru Venturi
Good luck,
Latexman
What would be the motive fluid ?
Here's an e-mail I got from Fox:
Thanks for visiting the Fox Venturi website! Is there a specific venturi application we can help you with?
Only very general product literature is available for downloading from our website. However, we have many more pdfs of more specific product information that we can email you immediately once we understand what product information will be most useful to you.
How can we help you? The best and fastest way to get the right answer is to simply tell us what you want to accomplish with a venturi.
We look forward to working with you - and thanks again
Larry Fox
Fox Venturi Eductors from Fox Valve Dev. Corp.
Dover NJ USA
973 328 1011 - Fax 3651
Good luck,
Latexman
It seems that steam or water at a pressure higher than 100 psi could do the job using an eductor.
A venturi is not an option here.
Sorry - can’t help you with this one. Thanks
Fox Valve Development Corp.
Good luck,
Latexman
Good luck,
Latexman
Clearly because there is no available pressure drop across the "venturi" (100psi in & 100 psi out) then this rules out the use of such a device. If you can tolerate a lower pressure than 100 at the outlet, then a "venturi" device could come into play.
For Eductors/Ejectors and similar technology, you could also look at Transvac Systems Ltd., based in the UK.
www.transvac.co.uk
