Yield Stress for Old Reinforcing Bars
I'm evaluating some concrete beams that were designed in 1926. Any idea what the yield stress for reinforcing bars from that era is?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
Yield Stress for Old Reinforcing BarsYield Stress for Old Reinforcing Bars(OP)
Red Flag SubmittedThank you for helping keep Eng-Tips Forums free from inappropriate posts. Reply To This ThreadPosting in the Eng-Tips forums is a member-only feature.Click Here to join Eng-Tips and talk with other members! |
ResourcesWhat is rapid injection molding? For engineers working with tight product design timelines, rapid injection molding can be a critical tool for prototyping and testing functional models. Download Now
The world has changed considerably since the 1980s, when CAD first started displacing drafting tables. Download Now
Prototyping has always been a critical part of product development. Download Now
As the cloud is increasingly adopted for product development, questions remain as to just how cloud software tools compare to on-premise solutions. Download Now
RE: Yield Stress for Old Reinforcing Bars
I suggest that you order a copy of "Evaluation of Reinforcing Bars in Old Reinforced Concrete Structures", Engineering Data Report Number 48 by CRSI.
Grades:
structural 33,000 psi
intermediate 40,000 psi
hard 50,000 psi
"Normal reinforcing steel ultimate strength of between 50,000 - 70,000 lbs per sq in with elastic limit (yield) at 25,000 - 35,000 lbs per sq in.
Cold working the bars will raise the elastic limit to 40,000 - 50,000 lbs per sq in.
Deformed bars have a higher elastic limit claimed at 50,000 - 65,000 lbs per sq in."
Hope it helps.
Per FEMA 356 Table 6-1, rebar typically came in 3 grades prior to 1968:
Structural: Fy = 33 ksi, Fu = 55 ksi
Intermediate: Fy = 40 ksi, Fu = 70 ksi
Hard: Fy = 50 ksi, Fu = 80 ksi
The following info is per CRSI Engineering Data Report No. 48:
Hard Grade is referred to reinforcing with Fy = 50,000 psi. and Fu = 80,000 psi.
Intermediate Grade is referred to reinforcing with Fy = 40,000 psi and Fu = 70,000 psi.
Structural Grade is referred to reinforcing with Fy = 33,000 psi and Fu = 55,000 psi.
These are tied into the following ASTM's:
1911-1966 - ASTM A15 (billet steel) (all three grades)
1913-1966 - ASTM A16 (rail steel) (Hard Grade only)
1936-1964 - ASTM A160 (axle steel) (all three grades)
I think you can get this document from www.crsi.org
