how to account for Latent heat of fusion
I was trying to model in the latent heat of fusion, how do I get to keep the temperature at melting temp
I tried using enthalphy values, where I appplied for 0 degree, 0 enthalpy and then couple of values around the melting temperature.. it seems to have no effect... maybe because the temperature that get calculted is way above the melting temperature???
I would appreciate any help or suggestion.
Thank you
Robin
