compressibility of Oxygen
I need to determine the compressibility of Oxygen at 100psig and 100F. Where can I find this information?
RE: compressibility of Oxygen
I have written a units conversion program called Uconeer (which is freeware) that will estimate the compressibilty of several common gases using Peng-Robinson. This is often accurate enough for day-to-day calcs like pipe sizing. You can download the program for free from http://katmarsoftware.com
An alternative is to use the NIST page at http://webbook.nist.gov/chemistry/ This will calculate the density of your gas at the stated temperature and pressure, and you can back-calculate the compressibility from that if you need it.
Harvey
Katmar Software
Engineering & Risk Analysis Software
