R,Cd,Omega values for ordinary steel frames
when using an R=3 seismic response coefficient, which does not corrrespond to the given values for ordinary steel frames (moment or braced) in IBC2003 or ASCE7-02, what values should be used for Cd and Omega? i cant imagine that the Cd value is the same as in the tables, when a user modifies the R coefficient to a lower value.
RE: R,Cd,Omega values for ordinary steel frames
