Problem with AOVLAP,,,,Help
Is there a way to select only the newely resulting areas from the boolean operation AOVLAP. The problem here is the output areas also includes some of the input areas.
Ex: Input areas: 1 2 3 4 5
OutputAreas: 3 6 7 8 9 10 11
After the operation all the areas (1:11) will remain selected and you dont know the only output areas.
I used BOPTN to delete input areas, but is didnt work as the input areas are attached to some volumes. I also tried to store the numbers of areas but no success as we dont know whether the resulting areas might include one of the input areas too.
RE: Problem with AOVLAP,,,,Help
Trust me, components are your friend. Once you learn to work with them, you won't be able to figure out how you worked without them.
Good luck. BTW good question and it was well-posed.
nodal
Why would you be performing boolean operations on areas that are already attached to volumes?
1.)If you use
numstr,area,arinqr(0,14)+1
the resulting area numbers beginning with the maximum area number plus one.
2.) New areas have none attributes. If you give the input (unmeshed) areas an attribute (real,mat,type,esys or secn) with the aatt command, the new area attributes are blank.
So you can select after the boolean operations all areas with blank attributes. For example asel,s,real,,0.
Olso I think, you can save all lines of input area in a component. After the boolean operation you can select these areas witch are attached completle on this lines. asel,inve will give you the new areas.
asel,s,,,1,5
lsla,s
cm,line_save,line
!boolean operation
cmsel,s,line_save
asll,s,1
asel,inve
cm,new_areas,area
Hope this is OK for you .... Stefan.
Thankyou very much for your suggestions. I have tried all you ideas but no success still. However, you deserve a star and you got it.
FYI here are the problems associated with each of your ideas.
My actual geometry input/output areas: (Original posting was just framed to illustrate my problem)
AOVLAP displays following output
Input areas : 120, 121 ,122 ,123 ,124, 125
Output areas: 124, 1300, 1301, 1302, 1303, 1304, 1305, 1306
(1) numstr,area,arinqr(0,14)+1
The resulting areas did begin with Max area number+1, but the unmodified area (124) is still there in my output areas.
(2) Attribute assignment
Same problem as above. The unmodifies area (124) is still having the given atttribute and got unselected when i selected areas with blank attributes.
(3) Line selection.
The unmodified areas got unselected by "asel,inve,". Also it selected many unwanted areas in my model (1:120)
In brief the unmodified area/s are the reason behind this problem. Also, the reason for this area/s not being modified is, it is totally within the domain of other input areas.
I wish ANSYS has a command to select/unselect areas resulting from boolean operations.
nodalDOF.
finish
/clear
/prep7
blc4,0,0,10,10,10
wpoffs,5,10,5
wprot,0,-90,0
cyl4,0,0,2.5,360,5,360,10
asel,s,loc,y,10 ! selects areas 4,7
aplo
aovlap,all !Input :4,7 Output areas: 7,13,14,15,16,17
finish
thanks
Nodal....
alls
cm,atmp,area
asel,s,,,1,5
cm,a_save,area
aatt,,100
aovlap,all
asel,s,real,,100
cmsel,r,a_save !-> unmodified input areas
asel,inve
cmsel,u,atmp !-> new areas
May be ANSYS destroy components during the boolean operation. hmmm. There is an other way to save areas.
Do you know something about vector operations in ANSYS?
OK:
! 0.) selection of areas
! 1.) Define a vector:
inp=
*dim,inp,array,arinqr(0,14),1 !Length of vector = maximum area number
! 2.) Save the selection status of (input) areas in column 1
! of vector [inp]
*vget,inp(1,1),area,,asel
! 3.) boolean operation
! 4.) Save the selection status of (ouptut) areas in column
! 1 of vector [outp]
outp=
*dim,outp,array,arinqr(0,14),3
*vget,outp(1,1),area,,asel !selection status
! 5.) compare selection status of areas bevore and after
! boolean operation
*vmask,inp(1,1) !Masking vector
*voper,outp(1,2),inp(1,1),eq,outp(1,1) !unmodified areas
!new areas ->
*vmask,outp(1,1)
*voper,outp(1,3),outp(1,1),ne,inp(1,1)
! 6.) select unmodfied areas
asel,none
*vmask,outp(1,2)
*vput,outp(1,2),area,,asel
cm,unmod,area
! 7.) select new areas
asel,none
*vmask,outp(1,3)
*vput,outp(1,3),area,,asel
cm,new,area
I have my ANSYS not here so it can be a error in my code. But normaly it must work.
.... Stefan.
NodalDOF.
FYI following is the input i am using......
-----------------Case 1-----------------------------------------------------------------------
finish
/clear
/prep7
blc4,0,0,10,10,10
wpoffs,5,10,5
wprot,0,-90,0
allsel $cm,atmp,area
cm,a_save,area
aatt,,100
aplo
aovlap,all ! Input: 4,7 Output: 7,13,14,15,16,17
asel,s,real,,100
cmsel,r,a_save ! I think this one is redundant....nothing changes
asel,inve
cmsel,u,atmp
aplo ! Remaining : 13,14,15,16,17 (7 is missing )
----------------Case 2----------------------------------------------------------------------
finish
/clear
/prep7
blc4,0,0,10,10,10
wpoffs,5,10,5
wprot,0,-90,0
allsel
*vmask,outp(1,1)
asel,none
*vmask,outp(1,2)
cm,unmod,area
asel,none
*vmask,outp(1,3)
aplo ! Again AREA 7 missing (13,14,15,16,17 selected)
We need a way to differentiate between the areas 4 (Present in input but not required in output) and 7 (Required in outpurt), both of whose status remains selected after the boolean operation.
What you are trying can't work.
Area 4 belongs to volume 1 and area 7 to volume 2.
What you need is the vglue command.
finish
/clear
/prep7
blc4,0,0,10,10,10
wpoffs,5,10,5
wprot,0,-90,0
allsel
vglue,all
ready
But attention!
You get some bad (peaked) areas for meshing in your example. Hope this is not a real geometry!
I connect such parts with bonded contact!
Why do you do'nt use the ANSYS Design Modeller for geometry import? He is more powerful then ANSYS Classic (Also in boolean operations!). If geometry import / modification is ready you can go to ANSYS Classic by exporting a ANSYS *.anf file for example or simulate the problem in ANSYS Workbench. (ANSYS Workbench can find contact regions automatically)
Best Regards .... Stefan.
thanks
nodal....
